Bhorn
What is best make of foam surround, for replacement? I also do not like idea of "touch placement", of surround for glue - in installment. This will be my first foam install, and find the precision of shim's, more favorable,vs other procedures. Including by feel for voice coil rubbing by touch. Also using signal to center, this still use's " touch " process to install. These are not exact as they should be. So cut dust Cap's, clean, examine voice coil, shim (proper), install proper best foam, made for these speaker's.
I checked price through this forum, and found pricy? Better grade? What gives?
Also what are best or recommended Cap's for cross over's? Where to purchase? Thanks from novice. Have listened to speakers, and they all work, hard to say what the sound is like without woofers fully functional.
