Mark, we know you are not.
I do have those Fairchilds in stock, I might give them a try. As I said I use them for switching purposes. Anyway, high speed BJTs in my rebuild do not make much sense, as I already installed 30Mhz MJE 15032/33 pair for a final driver pair.
I remember somewhere some highly technically inclined audiophiles were having seizures discussing Miller caps on driver stages in Pioneer C-21 pre-amp having 470pF values. Unacceptable design in theory, but the aforementioned piece sounds quite nice to my ears, mildly put! BTW, it showed up on that auction site two days ago, and was blown off in minutes for six bills.
The PA0016 is in most Pioneer Non-Switching Type circuit based amps. That covers all Black face high tier amplifiers; therefore there is no way to avoid it. IMHO it does OK job keeping bias values in check, and is pretty durable chip. I do have couple new ones (for ~ 20 bucks, sure)for spares, never needed them. A-80/90 are non-switching without the chip, and have some reliability issues. But they are Silver.
Rlovison, your cd/line problem might be bad switching relays RY301,302 on a buffer Amp board. Surprise, surprise they are the same as those “famous 13” relays on C-90 preamplifier. Therefore, the replacement is the same.
Having that in mind I shall give you part numbers at Mouser for one stop and shop. Cheaper, too.
Speaker relay RY 303,304 replacements should be Omron G4W-2214P-US-HP.
They are on a separate PCB behind the back panel close to speaker terminal block.
At the front at the big cap boards are speaker 4/8 impedance switching relays RY401,402. I would replace them with Omron G2R-24.
Buffer Amp relay RY301, 302 replacements would be Omron G5V-2-H1-DC12.
