Pioneer m90 Protection/power indicator
Unseenlegend
Hey im new here first time.
Living in the netherlands
First of all very happy with my pioneer m90 with sonus faber consertos
but to my issue here
first of all i when i notice the protection/power protection power indicator wont lid
this is my method of connection
connected to Line direct -> dac ''Marantz hd-dac1'' using RCA to RCA cable to usb cable to my pc
( Even with out the dac and turning the amp on still wont lid... )
Everything works fine.
I have no issues what so ever.
Is the Protection/power indicator even working?
I see no Yellow light nor red light
If bulb is only the issue does body have he knowledge ?
i have no luck finding the parts
I tried to look on the manual or service manual/ google but no luck.
Looking forward to any advice i can get
Regards to anyone that ''tries'' to read it
Hello,
Both lamps in the front panel are incandescent axial bulbs. Part numbers AEL1006 and AEL1007 are no longer available from Pioneer. One red and one yellow identical bulb. Both use a silicone boot that can be removed carefully and placed on a generic 8V 100ma, or so, axial instrumentation bulb. Many purchasing options available in general electronics suppliers and eBay. It's been a while that I bought several different versions in the 8V range, with different current specs to find the correct one. You do not want a too bright bulb as it could get hot and melt the silicone cover. I also experimented with several 12V bulbs to find options.
Removing the front panel and resoldering the new lamp is involved but doable by any qualified person with a soldering iron and patience. Care should be taken not to scratch the front face.
Good luck
................but to my issue here, first of all i when i notice the protection/power protection power indicator won't light up"
Did you ever get this resolved, fix, corrected, etc.? :dunno:
That Pioneer M90 is sweet! :thumbsup:
Ciao ! Have you adjusted the lamps?
