Pioneer PAX-30B restoration & cabinet build
jdsalinger
This is going to be a bit wordy, but it's for the benefit of future owners. I had to feel my way around in the dark because info on these is so scarce.
I picked these up locally caused I loved the looks, knew vintage Pioneers are something special and I needed a 100dB+ speaker for my 6B4G amp. The seller was very generous and gave me a very very god deal on them because there were a couple of cracks in the paper surround.
I tried to fix the cracks but I just didn't feel comfortable that they would hold up. If they are already brittle, then how much life is left in them? And how would that brittle paper surround affect the bass quality?
So, I researched ways to seal the surrounds and rejuvenate them. Got a lot of mixed opinions, but went to the hardware store to pick up some contact cement that had been recommended. Then, at the store, I started second-guessing & surfing again for more advice to get some clarity.
Found a post from a seemingly knowledgeable and experienced speaker repair tech who insisted that only a home-made solution from butyl rubber dissolved in solvent would work properly & stay flexible.
An associate at the hardware store and I started looking for butyl rubber products that I could dissolve, but came up empty. He then suggested, "what about flex seal?" (don't laugh).
I thought, "Well, it DOES say that it is liquid rubber, so why make my own flex seal, when I can just buy it?". Bad idea. Flex seal dries pretty plasticky and not rubbery. I should have tested it first.
So, yeah, in my haste, I ruined a pair of nice, vintage drivers. :mad: I felt certain that this stiffness would impact the sound, so I just threw in the towel and cut out the mess I had made and started to research what the best surround would be.
I realize that the prevailing wisdom is that foam surrounds will give the best bass and that cloth accordion style can sometimes suffer from peaks. But I really wanted to keep these vintage looking and similar to the original single rib paper surround and felt I could live with some mid bass peaks. Additionally, I was a bit concerned that the gold tweeter bracket would interfere with the foam "bubble".
The accordion ribs are much lower profile, so that's what I finally went with. I found that the only ones that seem to be pre-treated and the proper number of ribs and dimensions were from China.
Well, they got here much sooner than I expected. I bought some with a slight downward angle to the inner diameter.
Well, the re"foam" went great except I had some glue on my finger when I pressed the cone to test interference. Ugh!! What HAD been perfect cones now one had a grey-ish glue spot. I'm very OCD, so it made me want to just give up. I couldn't sleep knowing I had mucked up the cosmetics.
I tried rubbing charcoal dust to cover it up. That didn't work. Then tried pencil lead and that was also shiny.
I was SICK to my stomach. All that work down the toilet.
Well, after rubbing in the charcoal and trying to smooth it out, I noticed the glue spot started to lift, so thankfully, I was able to get a razor under it and peel it off the cone, just taking a little paper micro-layer with it. So, now the spot is nearly invisible. :banana:
Next crisis was that I neglected to use a 30Hz tone to center the VC. I learned that with alnico speakers, the VC gap is even tighter than others. One of the two ended up having some VC rub. CURSES!! Now I have to start all over again!
More research looking for any way to fix VC rub turned up a post by @spkrdtr where he suggested a hack that you can use to center a VC without having to refoam. Basically, you need to cut out the dust cap, shim and wet the spider with acetone. I didn't really want to cut out the VC which looked perfect, so I came up with an idea to use fishing line and a screw-type tensioner to put tension on the VC just enough to eliminate the rub. I set up a fixture and it worked really well. After two attempts, I now have a smooth speaker! Thanks @spkrdtr.
Next step is to get them installed in cabinets.
index.php
index.php
index.php
index.php
index.php
index.php
Wow at least they turned out nice in the end!
I was in a similar situation with a pair of Pioneer PW-38C woofers. The surrounds had really bad vanes in them, if I had played them I'm sure they would have torn immediately. I used clear latex sealant diluted down with water to the consistency of Elmer's glue and applied it to the front and back of the surrounds in several thin coats.
Worked perfectly, remains very flexible.
The thread title is misleading. I was planning on building cabinets when I found a pair of empty cabinets locally for $25.
They appear to be veneered particle board Barzilay clones and are about 4.6 cu-ft. They have some pretty ugly water stains on top but the sides and front are fine. I had to rebuild the front baffle and rear panel.
Having no idea how these will sound, it sure beats the expense and time of building cabinets from scratch. I’ve built large cabinets before and they turned out very decent for an amateur, but it is extremely tedious.
I think these will need a port but the plan is to test without first and then add the port & increase the port size if needed.
Great job replacing the surrounds and fixing the voice coil rub @jdsalinger. As for treating the surrounds, my recommendation would be the KLH & AR sealant sold by vintagear on ePay or member @RoyC. As for the cabinets you purchased, I think the size is acceptable and the port size selected will have the greatest impact on performance. I have a pair of ElectroVoice LT12 driver's in similar sized cabinets and they sound great. More info can be found by selecting the link below.
https://audiokarma.org/forums/index.php?threads/electro-voice-wolverine-lt12-info.873946/
Well, I'm about 90% done. Here's how they turned out. :thumbsup:
$25 for the cabinets. Had to make front and rear baffles. I have a total of $120 in these.
Currently, no insulation except the RH one has a 1" thick slab on the rear wall. I can't hear a difference between the two, but will do 1" all around the inside, based on Pioneer's prints for the PAX-A30.
Bass is much better than I had expected. They are well balanced and go very deep. No mid-bass peaks like I was warned might appear with the accordion surrounds.
The port size isn't necessarily scientific, but exactly the same dimension & close to the same location as the supposed original cabinet for sale here. http://classicaudio.jp/shopdetail/000000000199/
I figure they probably knew what they were doing (even back in the 50's) and it was a good starting point. 3"x12"
I am very very pleased. They sound wonderful but I've only had a total of (2) half hour listening sessions using my 2.5watt 6B4G SE amp. I'm sure I'll add some more description after they break in a bit.
index.php
index.php
index.php
