VTX66
Hello!
I recently bought a Pioneer PD-204 CD player.
First time I plugged it in, the problem was there: closing the tray and the disc is not spinning up. I tried with like 5-6 discs, and at some point one of the motors started to spin up (with a bizzarre noise which was gone after a few secs). Then it did the read, and started play perfectly. From then, I played like 5 different CDs, all worked well.
Here comes the next day. I switched it on, ejected the tray, put on a disc, and the same problem occured. Not spinning up. Again, I tried a few discs (more than the first time), and nothing... and after like 20 minutes of trying I heard the same bizzare noise as the first time, and finally it worked again perfectly, no unusual sounds after.
And here we are today, again trying to open-close the dray with different discs. But now nothing. I've tried with 3 different discs alltogether like 50-60 times, but now it's not spinning up.
I've searched through the internet, but most cases were the lens falling out. I opened up the case, but mine's lens is in the perfect spot, no problem there.
I did a video of the inside while loading a disc, but wasn't sure what to film... You can see/hear the lens moving up-down 4 times, then giving up.
So... what's the deal here? It's really annoying me now. Really hope you can help.
Thank you.
Thank you.
