Bloodnok
As stated, the disc cartridge won't go in all the way. It was initially stuck, but I was able to disassemble the chassis and get it out. Now it won't go back in. There is a lever on the left side of the slot the cartridge goes into, and that appears to be the problem. Does anyone know enough about this design to know if I got something out of alignment or some switch out of sync? Also, it contiously tries to load a disc, even with the power off! The manual doesn't go into a lot of troubleshooting...
Thanks;
Thanks;
