Pioneer PL 115D suspension question
byrdmk
Member
When the platter on my Pioneer PL115D spins a heavier, 180g record, it sounds like the platter is scraping the bottom of the turntable somehow. As if the record is too heavy, and the platter is bottoming out.
Anyone know how to adjust the suspension on this table? Ever done this before? Would love any help that you gurus out there could send my way...
Thanks in advance,
Mitch
Lock down the tone arm, remove the platter, flip the table over and remove 6 or 8 long screws. carefully lift up the base, there will be a blue wire attached to the base, unplug it. Remove the base, you should find 4 black adjustment cams. adjust them up to 2nd or 3rd from the top. This should correct the problem.
