Okay, what confused me is that you said in your original post that this was a belt drive turntable and that it needed a belt. Then after you got the motor working, you said you played an LP. And I was confused because you never mentioned anything about getting a new belt. Now going back a few posts I see where you mentioned it was an idler wheel drive. Never knew Pioneer made any--and I'll bet most others didn't either. There was also a PL-A25 which was belt drive and that might be what those belts are intended for. I don't know of any PL-25F. Where did you find mention of that model?
Anyway, does the original capacitor have polarity markings (+-)? If so, it's a tantalum which was a type of electrolytic, and would require that kind of replacement, since the polarity matters. Otherwise it was just a large cylindrically shaped ceramic or a mylar, and polarity is not an issue, so those polys would work fine.
