Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Picked up and old PL-400 direct drive at the goodwill. Plugged it in and the platter agitates like a washing machine. That's one I've never seen. Any guess as to a remedy.
What you described is generally caused by a missing F clock (TP4 on the motor drive board, comes from IC1 (PD1003), pin 15). If so, sorry, parts unit time. They don't make that chip anymore.
You will need some tech knowledge, an oscilloscope, and a service manual.
Yes, the motor will rock back and forth without the platter installed, but the original description of the problem stated that the "platter" rocked back and forth. Hence, my confusion.
