Hi,
Just bought this turntable from Japan.
The turntable is running perfect on 45rpm, and everything else is great aswell, end of play hall element adjustment is spot on. But the quartz lock at 33 rpm is just about flickering and making this on/off noise from the motor. Hence I would like to try and adjust this, but it turned out to not be that simple.
Found a manual (though for the higher spec Pl-70Lii but they share much of the same, the PCBs are same). Having a bit of trouble understanding what does it mean when they say connect buffer amplifier to pin.. what am I supposed to connect and how? And also with the VR1/2 they dont mention which of these as there are two sets of the same.
I'm also having trouble to raise the tonearm from its lowest position. Or it's way to low as the cartridge hardly can reach the mat.
Anyone experienced this maybe?
Would love some help!
Thank you all.
Thank you all.
