I unplugged my DD turntable about two days ago to remove the old stand and await my new cabinet setup. When I plugged it back up today and started to play, I noticed a gritty dragging sound then saw that the strobe was showing that the speed was fluctuating in a pulsing pattern. I figured it might need some Deoxit in the speed pots, so I sprayed them and they seemed to turn faster and smoother. Still pulsing. Also sprayed the buttons for 33/45 and then the on/off switch and finally sprayed some into the motor itself after removing the platter.
A couple of times after spraying the motor, I had to give the platter a little help to spin up from zero. Then while toggling the on/off switch rather quickly, the motor just stopped. I manually spun the platter but could tell the motor was seized. Should I keep spraying Deoxit all over the place, or was that my mistake? Is this fixable? What should I do?
Many thanks!
Many thanks!
