evanbalthaza
Hi hello!
I recently replaced some foam in my turntable and discovered a stripped internal thread in reassembly. The other three screws tighten completely and hold suspension on the spring, but the fourth screw's spring spins once "fully" screwed in and doesn't hold the motor assembly high enough to avoid platter grinding.
I've purchased other suspension screws to ensure it's the internal thread and have tried using JB weld to repair the threads using the screw as a guide, but this hasn't worked. As a result of overtightening I've also driven through the plastic faceplate under the platter, so I'll need to plug that as well.
I just wanted to post and garner some opinions or thoughts on the best move to take next. After researching internal thread repair, it seems like the only option short of retapping would be a helicoil so if I can determine the right size and find the correlating kit I might try that. Is it worth trying or does it seem likely to damage / crack plastic?
