A few days ago I sort of grazed/bumped into my PL-514's tonearm while the cue arm was up and immediately after that the tonearm/needle drags directly across the record when I play it. Earlier in that same day it was fine, which leads me to think it isn't just that the cartridge needs replacing (although admittedly I could use a new cartridge.)
I received this turntable from my uncle and it's been in great shape for the past ten years, so far the only repair I've made was a belt replacement one time.
I found a specialist (in the NYC area, so they're in the Lower East Side) that will take a look at it but charges $75 just to examine it, before they can even give me an estimate.
My question is - does this sound like I'm about to enter a rabbit hole of high cost to repair this thing? Is the turntable worth keeping? I wouldn't consider myself an audiophile, but I love listening to records and really like this turntable, especially given the family connection.
I tried recalibrating the weights and was having trouble - it almost seems like something might be off in that department as well - couldn't find a proper balance with the counterweight.
Are there any guesses as to what might be causing the issue so that I can be prepared? Also any suggestions in the NYC/NJ area that might be an alternative place to bring the turntable would be welcome.
Thank you!!
Thank you!!
