sinnerboy
Well-Known Member
Diagnosing the auto return issues with my PL-540. Before I get to the problem, kudos to me for soldering the tonearm wires back to the harness, two had broken off during my working on the return mechanism. First stripping the tiny wires was a delicate procedure, but when it came to soldering them back in place, my 64 yr.old eyes had a hard time seeing what I was doing. But I succeeded before I executed my plans to appeal to someone here to do the job for me. But that's not what I'm here to talk about.
Symptoms are when the auto-return kicks in, the tonearm moves back to pedestal, then the auto-return mechanism gear re-engages, turning the motor back on and the tonearm just sits off the pedestal while the auto-return mechanism iterates on and off.
Everything else is working, auto-return kicks in at the appropriate point in playback, arm moves to arm rest, micro-switch is deactivated, motor turns off. Then, it appears that the momentum of the table rotating engages the auto-return mechanism again, closing the micro-switch plunger, starting the motor, starting the whole process over.
I'm thinking the trigger on the auto-return gear is re-engaging when it shouldn't. Not sure how to fix this. This pic is after it has gone thru the return process, you can see the trigger still positioned to catch the drive gear lobe as it spins by. I can see how it's supposed to work, the trigger has a lobe at the front end that, as the drive lobe engages, it pushes the trigger out of position. Well, that isn't happening. I did clean and lube the trigger, not sure what my next step is. Any suggestions?
