kapohoguy
I'm new to AK and really appreciate willingness of this community to share knowledge. I have a problem with a Pioneer PL-560 turntable I recently acquired via Craigs List. I knew it had a couple of minor issues I could see before I bought it--broken tonearm rest, broken rubber feet, & minor scuffs on the dust cover. Otherwise it looked very clean & even had a decent cartridge & stylus (more on that later). Tested before buying and the mechanics and electronics seemed fine. Back at home used Shoe Goo to repair the rubber feet, replaced the tonearm rest with one I had in the workshop parts bin, and polished out the dust cover scuffs. (see photos attahced). Unfortunately, it has a new problem that didn't emerged until I started playing records. In automatic mode the tone arm set down point is erratic. Sometimes it hits the lead-in groove perfectly. Other times it sets down about a half inch from the edge of the record. Other times comes up short of the record by a quarter inch. The next time it might set down about an inch from the record edge. It is erratic and unpredictable. This is with the Record Size selector knob set to 12". I've tried the 7" and 10" settings with similar erratic results. Every thing else seems to be functioning correctly. It cues up and down perfectly. The auto-off function and Cut button return the tonearm to the rest and turns off the power exactly as it should. I've tried turning the stylus descent-position adjusting screw, but it has very little to no effect on this problem. I've read through other posts about this and similar Pioneer models and have already replaced the foam pad that seems to deteriorate on these models. That had no noticible effect on the problem. One person suggested I remove and replace the old lubricant, but the lube grease seems fine to me. I may try that if I don't get other ideas.
Has anyone else had this problem or know a solution? Any help would be deeply appreciated.
Also, does anyone have info or opinions on the Emprie model 2010 cart?
Thanks.
Thanks.
