About 2 weeks ago, thanks to the most appreciated help from this forum, I declared success (prematurely) with intermittent Right Channel no sound. I have double checked all cabling, bypassed preamp to direct connection with receiver phono input, deoxit on all connections. I have sound for a record or two, but either flipping to side 2 or initiating a play session next day, issue returns, no right channel. Unplugging from power, turning receiver off then on, turning preamp off then on sometimes restores right channel (????)1. Head shell removed for rest of tests/ continuity tests are from the 4 tonearm collet pin
2. Right Channel collet pin to RCA connector right pin has no connectivity. Other 3 connections OK
3. Molex Connectors to end RCA Connectors R Pin, R Shield, L Pin L Shield all OK connectivity RCA cable itself in-spite of my rookie soldering skills on RCA connectors OK.
4. PC Board output pins/fins to Tonearm Collet Pins ...Right Channel Collet Pin to Right Channel PC board right channel pin/fin...no connectivity.
Attached is photo of PC Board with molex connector removed...I can see 5 solder points to tonearm, and 4 solder points to mute switch.
*tracing the green and red solder connections from solder point on PC Board to red and green solder connections to Mute switch....I observe that it appears that the green (right shield) connecting to the red (right shield) connecting to the red wire from mute switch at the solder point...same with the red from tonearm connecting to the green from mute switch. This is not right...but could this be a cause of intermittent right channel issues?
Would the solution be to snip and resolder these connections? I tried to remove the muting switch but the screw attaching it to the board will not budge. Could I just snip the 4 wires to the muting switch? Didn’t want to do any of this until I was sure that would help .... its the intermittent nature of losing the right channel...seems like it should be either always on or always off.
Thanks again for your patience...any advice most appreciated.
Steve
