Led-Zep
I have read every page of Rich's thread here: https://www.audiokarma.org/forums/index.php?threads/restoring-a-pioneer-pl-630-turntable.92333/
It might be easier if I start a new thread rather than add onto the 12+ pages in Rich's.
I purchased the turntable several months ago and it was doing well except for the tonearm belt. I successfully replaced the belt and enjoyed using the turntable until the back-and-forth speed problems started.
CRC Contact Cleaner is what I use because Deoxit is nearly unobtainable in Hawaii. I have to order it from the US mainland and aerosol cans aren't allowed with the post office.
I have been focusing on the 33/45 speed, Quartz Lock and speed control pot for cleaning. The turntable was working after cleaning then a day or a few days later started going back-and-forth again. I also disassembled the power switch, carefully cleaned it and reassembled it. I used 1500 grit sandpaper and no contact cleaner.
Now it's been several days since the turntable has operated properly. Today I opened it up again (probably the 7th or 8th time since I started "fixing" the turntable), sprayed contact cleaner in the pot a few times, rotated it and sprayed the Quartz lock and 33/45 switches multiple times, pushing them down and releasing.
The reassembled turntable still doesn't spin properly and now there's a NEW problem! When plugged in, the power is on, regardless of the power switch position. I took the turntable apart again and checked the power switch and wires. Everything looks intact. I did not disassemble the power switch again.
I've been thinking it would be easier to simply replace switches rather than fiddle with them. Another poster had provided information about switches on Digikey, specifically these switches: 401-1194-ND 6PDT and 401-1193-ND 4PDT. The website says they are not available.
Looking at Mouser, I am just taking a shot and looking at parts that appear similar.
I found these:
Possible replacement pot: https://www.mouser.com/ProductDetail/652-PDB182K420P104B
Possible replacement switches: https://www.mouser.com/ProductDetai...=sGAEpiMZZMtC25l1F4XBU1xwXnrUt/uoOuufGbOMwIM=
Your thoughts and recommendations are appreciated.
Mike
I found these:
Mike
