RichardSusan
I am not an audiophile by any stretch, but about a year ago I resurrected my old Pioneer PL200X turntable, and replaced the cartridge with a Shure M97xE. Everything sounded fine, at least to my old ears, until recently when I put on a record and heard normal volume from the left speaker, while the right speaker was barely audible. After tinkering with the headshell wires (two seemed a bit loose), I tried another record and found the situation reversed: strong right speaker and weak left. I continue to fiddle with the headshell wires, checking for loose ones, but the problem remains. Everything else in my little system functions as it should (FM and AM radio, CD player), so I assume the issue is with the turntable. My uneducated guess is that I need to replace the headshell and its wires. Is that a reasonable assumption that is likely to solve my problem, and if so, what should I look for as a replacement headshell?
