platevoltage
I'v finally picked up an Ikea Lack table as a stand for my rig.
Since then, I have excessive acoustic feedback and woofer pumping.
All of the boots on the spring suspention on my PL610 are toast. They have disintegrated. They are not fixable.
I've set the spring height a number of different ways on this TT to no avail.
Any ideas out there for boot replacement and the setup of the spring sension on the feet?
As this is designed, the feet basically hold the plinth solid and the lower chassis / TT assembly hangs from springs that sit around each of the feet. The spring tension on each foot is adjustable via an acme thread and spring seat built into each of the feet.
Right now my only remedy has been to set the TT on a 1/2" piece of drywall and below that are 4 airbags (the type used as packing material)
I'm in the process of building a inner tube mount with three seismic bearings.
I've heard that this is not optimal for suspended TT though.
I should add that the problem is so bad that the whole TT will "ring" in resonance with bass passages. If I put my hands on the plinth and press down it will stop. The problem is almost gone with the airbags underneath.
