Pioneer QX8000 FM Tuner problems
Andrew Dowd
I have a Pioneer QX8000 receiver that I’ve had for nearly ten years. Recently the FM tuning started to go bad. It’s not a reception issue- I live in a area where FM reception normally is excellent without an antenna. The problem started out with the station coming in perfectly clear - then suddenly I’ll hear static and a “pop” and this combination repeats for about 15 to 30 seconds. Now I only get static all the way through the FM dial. I’m assuming that the FM board (or is it a chip?) has gone bad. Is this repairable? Horribly expensive? Aside from this, everything on it works great (save for a bunch of blown display bulbs). Oddly, my other receiver (A Sansui 5500) is in the repair shop for the exact same problem.
Are you sure something in the vicinity of the units is not intermittently arcing and radiating the noises (since both seem to present the same symptom)? I have seen things like a bad timer on a cloths dryer, and a bad aquarium heater thermostat radiate tremendous RF hash noises intermittently.
I'm absolutely certain that it's not that. I say that because I recently got my old Sansui 5500 out of storage to use as a backup replacement, and the FM reception on that worked great for about a week when the FM went out on that one. And this was a completely different problem where I got nothing.
New appliances (TV's, etc.) all put out RF hash, with cell phones, tablets, or laptops being the worse in my case. I've found over the years that I have to move them away from my consoles(at least 5 ft away), or components just to receive a decent FM or AM signal. No TV's, cell phones, laptops in the basement.
Best bet to use a 75ohm shielded cable to your antenna. Use a grounding lug (similar to that used on cable tv Run), and a 6ft ground post.
my house is a hot bed of made in china crap that i used to play pure with hell on AM/SW reception. ive had to add filters even to the power supply of my desk top computer. everything even chinese led light bulbs can cause issues wall warts too i solved all that by erecting a proper outside random wire antenna with a coax rg58 lead in and water pipe grounds to my sx42 and sx62 hallicrafters. i have NEVER had an issue with fm reception using either the factory wall hanger dipole or even a wire in my workshop that goes outside to the concertina wire on top of the wall. i was told and read that fm is much clearer than AM by virtue of the way the signal is processed. i hate disagree in public as i dont pretend to even approach your level of expertise.but i do. my advice to andrew is if any doubt exists all you need to do is take it to a friends house with a set of headphone's this will positively eliminate the environment or confirm it. my guess is you will need a signal tracer to find it if im correct. it was not my intent to ruffle any feathers here.
