Hello Guys, I'm newbie here...
My pioneer SA-1000 int amp has problem before due to encountered blown main fuse, the root caused was busted/shorted 2pcs. Toshiba 2SC1080 power output transistor on the Left channel power amp... But when I replaced it with substitute ON Semi MJ15015, it shown on DVM that the reading on "idle current adjustment" was too high (Left channel: 125-130mv Right Channel: 02.3-02.5mv) even adjusted the VR4 at the minimum...
