I have a Pioneer SA-500 integrated amp that I forgot I had, so I decided to bring it back to life. I have replaced all the caps and the 4 emitter resistors (one looked like it was falling apart), which went well. I then found one of the 2SC458LG's was noisy, so I replaced both with 2SC2240's (marked C2240/GR 5J), which seemed to be the recommended replacement. I have now discovered that one of the 2SC870's is noisy, so I would like to replace all the 2SC870's and 871's. This is the part I'm having trouble with. I have seen recommendations for the 2N3707 and the KSC1845, but the specs are very different. I understand caps and resistors, but this transistor stuff has my head spinning.
I'm hoping someone can point me in the right direction and perhaps enlighten me a bit on what specs are the important ones when attempting to sub transistors.
