it isn't in the same package. The original transistor is in a TO-220 and the equivalent NTE36 is in a TO3P package.Change your test frequency, does the noise you hear change too? If so that's normal and only reason you hear it is because there are no speakers to drown it out. If it was oscillating it would be at such a high frequency you can't hear it.
Crat
Ok, I'll try it when I'm at the bench. Thanks for the replyThe noise you hear is the circuit, the power xfmr, possibly the heatsinks, it's all normal without speakers to drown it out. Tube amps are even more noisy as you can hear the output xfmr singing. The frequency of your noise changes with your input signal?
I tried playing music and it sounds fine. I thought that the music was louder than the noise, so that is why I didn't hear it.it's the outputs singing .try playing some music to confirm .
