Hi
My old Pioneer SA-710-II made a lot of noise, hum and pops, even when there were no music playing. The relay were also clicking right away when it was powered up, which resulted in a huge pop, when the power was turned on. I thought the problem was some bad capacitors so I ended up replacing all the electrolytic capacitors, besides some non-polarized ones which i could not find replacement for. I have also replaced the two big 12000 uF capacitors.
There are still some hum on the AUX-channel, but I think it is better than before. On the phono-channel there are still pops. I have tried connecting my turntable to phono and the signal is amplified, so I guess the preamp works. The relay is still clicking right away.
I am wondering what I should do next? It is the first time I am trying to repair an amplifier, so I am definitely not an expert, and unfortunately i do not have an oscilloscope or dummy load. Any suggestions on what could be causing this problem?
Thanks in advance
Thanks in advance
