Segasonic91
I am still battling to get my SA-7500 up and running after a backwards cap did damage that has kept it in protect.
I found 2 of the SR3AM-4 rectifier diodes were shorted and replaced them. Still no go. When testing with DMM set to ohms, I am getting a stable 10.7 on 2 of them, one is jumping all over and one shows as open. I want to replace the ceramic caps that are in line with those resistors as well as the one with the SIB01-02. I plan to replace those, also as again, 2 stable readings and 2 all over the place. I have already replaced output transistors and 2 of the 4 power transistors. Last thing, and I hope it is the last, is the 2 fuses.
I just bought a PIONEER SA-9800 (9500) from Japan so I want this thing done before it arrives or it may never get done!
