Pioneer SA-7500 II recap list
dbayles
Here's my capacitor list for replacing the electrolytic capacitors in my SA-7500 II amplifier. The only capacitors that don't have an entry are the two large filter capacitors. I have posted a separate thread regarding those items since there is no exact replacement available and their replacement will require some retrofitting.
Since I didn't see a capacitor list for the SA-7500 II, I'm hopeful that this information might get archived with AudioKarma and that it may help another rebuilder in the future.
I should also add, that in addition to pulling the specifications from the service manual and schematic, I did go through the unit and confirm that at least in my unit, these are the actual capacitance and voltages for the units as installed. As per a post I read from markthefixer, I have formatted the list as a comma separated values list so that you can easily read the information into a spreadsheet. As always, if you see anything out of kilter, let me know. I'm open to suggestions and somewhat trainable (depending on who you ask!:))
Nichicon PW series for the Pioneeer CEA capacitors,,,,,
Nichicon KL series for the Pioneeer CEANL capacitors,,,,,
Control Amplifier Assembly,,,,,
Capacitance,Voltage,OEM_type,OEM_value,Service_manual_label,Mouser_Pt_No
47uF,6V,CEANL,470P,C5,647-UKL1A470MDDANA
47uF,6V,CEANL,470P,C6,647-UKL1A470MDDANA
3.3uF,50V,CEANL,3R3P,C9,647-UKL1H3R3MDDANA
3.3uF,50V,CEANL,3R3P,C10,647-UKL1H3R3MDDANA
47uF,35V,CEA,470P,C19,647-UPW1V470MED
47uF,35V,CEA,470P,C20,647-UPW1V470MED
AF Amplifier Assembly,Voltage,OEM_type,OEM_value,Service_manual_label,Mouser_Pt_No
1uF,50V,CEANL,010P,C1,647-UKL1H010MDDANA
1uF,50V,CEANL,010P,C2,647-UKL1H010MDDANA
220uF,25V,CEA,221P,C9,647-UPW1E221MPD
220uF,25V,CEA,221P,C10,647-UPW1E221MPD
2.2uF,50V,CEANL,2R2P,C23,647-UKL1H2R2MDDANA
2.2uF,50V,CEANL,2R2P,C24,647-UKL1H2R2MDDANA
2.2uF,50V,CEANL,2R2P,C31,647-UKL1H2R2MDDANA
2.2uF,50V,CEANL,2R2P,C32,647-UKL1H2R2MDDANA
47uF,6V,CEA,470P,C35,647-UPW1A470MDD
47uF,6V,CEA,470P,C36,647-UPW1A470MDD
330uF,6V,CEA,331P,C45,647-UPW0J331MED
330uF,6V,CEA,331P,C46,647-UPW0J331MED
100uF,16V,CEA,101P,C47,647-UPW1C101MED
2.2uF,10V,ACH-317,,C48,647-UKL1H2R2MDDANA
10000uF,50V,ACH-062,,C49,667-ECE-T1KP103EA
10000uF,50V,ACH-062,,C50,667-ECE-T1KP103EA
330uF,63V,CEA,331P,C54,647-UPW1J331MHD
330uF,63V,CEA,331P,C55,647-UPW1J331MHD
220uF,63V,CEA,221P,C56,647-UPW1J221MPD
47uF,25V,CEA,470P,C58,647-UPW1E470MDD
100uF,63V,CEA,101P,C59,647-UPW1J101MPD
220uF,25V,CEA,221P,C60,647-UPW1E221MPD
220uF,25V,CEA,221P,C61,647-UPW1E221MPD
220uF,25V,CEA,221P,C62,647-UPW1E221MPD
BOM List,,,,,
Mouser_Pt_No,Quantity,,,,
647-UKL1A470MDDANA,2,,,,
647-UKL1H010MDDANA,2,,,,
647-UKL1H2R2MDDANA,5,,,,
647-UKL1H3R3MDDANA,2,,,,
647-UPW0J331MED,2,,,,
647-UPW1A470MDD,2,,,,
647-UPW1C101MED,1,,,,
647-UPW1E221MPD,5,,,,
647-UPW1E470MDD,1
647-UPW1J101MPD,1
647-UPW1J221MPD,1
647-UPW1J331MHD,2
647-UPW1V470MED,2
667-ECE-T1KP103EA,2
