Hi guys,
I have a Pioneer SA-7500 II with a defective right channel, I see the signal is clips and distorts, when I turn up the volume.
The first thing I did was to clean all the amplifier controls with contact cleaner, but the fault persisted. So, to identify where the problem is I have injected a 1KHz signal through the Aux input and measured at test points T46 and T48, which correspond to the output of the preamplification stage. At this point the signals are identical, so I have assumed that the problem is further downstream in the amplifier stage.
I made more measurements and the signal begins to present problems when increasing the volume at the base of Q4, which is a “differential” chip (I think) that contains two transistors inside. I have thought that this chip is responsible, so I exchanged the right channel chip with the left channel chip, hoping that the problem would now occur in the left channel, but it was not. Continue measuring and everything looks fine, the capacitors are fine, the transistors are fine.
Because of this I decided to apply brute force and have swapped, in the amplification stage (enclosed with the green box in Diagram1), all the components (but the resistors) of the right channel with the components of the left channel, one by one hoping to identify which component is causing the problem. But I have had no luck, the problem remains in the right channel. All these measurements and tests were done using an 8 ohms dummy load on each channel. Then it occurred to me to measure without load, so I removed the 8 ohms dummy load and measured at the output of the speakers, and the signals are identical !!!!
In short, the right channel only distorts the signal if it has a load connected and if the volume is turned up.
I thought it could be the relay, I have disassembled it but I have not been able to open it, I feel like I am going to break it, this is not the original (I think), but it looks in good condition (it has a transparent cover and you can see the contactors through it).
Could you please guys help me identify where the problem is?
In the attached photos:
Diagram1: In blue is marked where the signal is correct and in red where it is clipped. The green box indicates the area where the components have been swapped from one channel to the other.
The other photos have descriptive names of the measurements made with my oscilloscope.
Thanks and have a nice day.
