kasbah512
Member
I see now. I'm looking at the schematic and that does make sense given that I'm seeing close to -1v at points noted in the initial post. However, I do wonder why this is happening in the first place. That's what I'm failing to understand. I also do have reservations about changing resistors to correct what shouldn't happen in the first place from my understanding (I have a fear of working on it down the line and issues arising from resistor values being inconsistent with the schematic), but if that my best bet, ill give it a try and report back.You can replace as many transistors as you want. It's your call. Replacing Q5 and Q6 will have almost no effect on your output offset voltage. The best solution is to reduce R42 to something like 10k.
