I just picked up a Pioneer SA-7800 to restore as a summer project. The phono section is having some issues. But, I am learning that this seems to be a common issue and I am lucky there is a lot of information out there to help guide me when fixing this.
The main reason for my post is a question about the different Nichicon capacitor series. To give you some background, my first recap project was a Yamaha CA-610 while in COVID isolation 2 years back. I made many mistakes in that project but learned a lot in the process. When recapping the Yamaha, I decided to go with the highest-level Nichicon audio caps (UKZ, UFG) in every location. I understand the error of my ways now and feel a bit silly installing these in the areas such as the VU meter circuit.
From a couple days of reading about the SA-7800, I have gained a high respect for markthefixer. I have seen some of his recap lists for the power supply and power amplifier assembly, which recommend low leakage (UKL)/low impedance (UPW) caps. After seeing these lists, I just assumed I would use the audio-grade UKZ/UFG caps in the phono circuit. However, I just came across a post from markthefixer recommending low impedance (UPW) caps in this circuit, and I was surprised.
My main question here is what are the benefits in using the low impedance series of caps in this circuit over the audio-grade UKZ/UFGs? And, if the best choice is the low impedance caps, when is it appropriate to use the audio-grade caps? I am asking this question to learn from the experts here on the board who are familiar with the SA-7800. I do know there are many forums that go on for pages regarding the choice of capacitor, but I was hoping there was a simple answer for this specific situation.
Thanks!
Thanks!
