dbxdx5
I'm trying to track down some high DC in the preamp section of an SA-8100. When I have the pre and amp sections coupled, the protection relay trips intermittently. When they're separated, the relay is quiet.
Right now, I'm measuring approximately 1.1V and 0.700V DC at pins 11 and 6 (the outputs) respectively of the filter amp board. There's no DC at pins 4 and 13 (the inputs). I've replaced the four light blue Sanyo caps on the switch board (AWS-035), as well as the 10uF/16V caps on the filter board. I'm thinking the source of the DC is on the filter amp board, though the only suspects would be the 330uF and 1uF caps or the two 2SC1313s. Or could the DC be getting into the filter board from somewhere that I'm overlooking?
