crustypaul
I have a really baffling issue with my Pioneer SA-8500.
The right hand channel developed crackling and popping due to dying transistors on the power amp board, so i replaced the 2SA726's at Q2 and Q4 on the right with KSA992's and the 2SC1451 at Q6 with a KSC3503. This went ok and the amp seemed to be working perfectly again, but i thought i should change the transistors on the left as well. I swapped them over in the same way and switched it on, and the speaker protection relay wouldn't engage.
I took out one of the new KSA992's on the left and replaced it with one of the original 2SA726's and still nothing, so i replaced the other new KSA922 with another original 2SA726 and the amp came back to life....
After much messing around i found the only way to get it working was if Q1 and Q3 on the left were both the original 2SA726's. If either of them are KSA922 then it won't switch the relay when you turn it on.
I was wondering if somehow the pinout diagrams on the board were wrong, but that makes no sense as surely its exactly the same as on the right. On the right the 2SA726's are BCE and the KSA922's are ECB so i just installed the KSA922's flipped around.
I feel like i'm going mad here. It doesn't seem like this should be possible. Am i missing something embarrassingly obvious?
