Trying to sum up...
Some amps come with AC sockets for the connection of additional equipment, typically a turntable.
These sockets provide mains AC, eg, 240V in, 240V out on ALL sockets. They are normally
rated at 10A, 250V (Not OK for Aust because of transients) and maybe 200Watts
The sockets may be labeled as SWITCHED or UNSWITCHED.
SWITCHED sockets will only be live/deliver power if the amp is turned ON
UNSWITCHED sockets will be live/deliver power regardless if the anp is ON or OFF
(assuming amp is plugged in wall socket and powered ON there).
The SG-9800 may have a voltage selector at the back where you can select 240V, only
after switching to 240V on the SG can you plug the SG into the amp.
If there is no voltage selector on the SG then there is a remote chance the transformer
can be rewired to 240V, however this is extremely unlikely since Pioneer would have
provided the "voltage selector" option.
You will most likely need a step down transformer (240/230Vac -> 120Vac). Autotransformers
are the cheapest but do not provide isolation. I would not buy one. Prefer a torridal transformer
over the old EI type (lower noise, power consumption...) maybe cost AUD200- or DIY for AUD150?
To be honest, I wouldn't bother with the SG. You have a decent amp, spend the $200- on a
partial refurb on the amp if needed.
