Pioneer SA-9500 II restoration-the final frontier-Take TWO
Ricktptman
High Fidelity Enthusiast
Okay, I initially set out trying to pull a single compromised (multiple switches brutalized-but otherwise functionally PERFECT) one of these back from the "parts unit" abyss and tried to sub out unobtanium switches. Some worked acceptably well, some didn't. I rehabilitated one of the three with a "stump" on the shaft to usability, but the other one is still way too stiff. I found a 50Hz stepped tone control that subs out with some spacer mods. Now, I just picked up a parts unit with ALL of the switches I need, but with one (balance) pot that missing 1/2 of the split shaft. But IT has this "hum" ground potential issue with ONLY the phono board. I renewed contacts, tightened the boards (the phono input jacks were loose and not securely reattached) and cleaned the grounds on the phono board contacts. It's better than it was, but the problem remains. The biggest symptom is when you change the cartridge loading K ohms pot on the bottom control. The top one has very soft clicks when switched from one setting to the next. But the bottom one trips the relay when switching to and from the 100K ohm position. At first, I suspected the PS caps (not my first "go-to" on any occasion), but because this unit wasn't packed well and while FedEx did a decent job of not destroying it I checked and a few were noisy when poked and prodded. I resoldered them and they settled down. I did find a fuse knocked loose, which means the trip wasn't feather bed gentle. Any advice is appreciated. TIA...
