FRANKPIETTE
Member
Hello There!
I'm looking at a Pioneer SA-9900, I noticed that on the power supply board there's 2 470uF 80V caps. They're three legged, really not common with three legs, i checked, Digi, Mouser and many more those i found are not available. According to the underfoil pictures from SM, they show them as a 2 leads, can i already be sure the 3rd leg is a dummy? On board the one still on, has its 3 legs are connected to action and no legs on an isolated patch. Anyone had the same problem? What replacement have you used?, If the 3rd leg his a dummy (anyways) i have many 2 legs 470uF, 80 volts caps.
