Good day AK members! I got this little Pioneer SA540 amp for cheap as not working. After some time inspecting it I found that speaker terminals have to be replaced (damaged, not working anymore). Did give this unit a good cleaning inside and outside. I have also replaced speaker terminals. The 1A fuse on the inside was blown, so I replaced it. Power up, and it immediately blow up again. Further inspecting, I found some "leaking caps", but in the end it turned out to be just glue on top. Anyway, did a whole recap using Silmic II and Nichicon FG. Put in a new fuse and it blows up immediately again. Did some searching on the internet, and I couldn't find any related threads. Just for being safe, I replaced 3 diodes (2 normal ones, and one bridge 4 pin). Also replaced 2SC2240 and 2SC2235 near the fuse (Q401 and Q405). Power up, and it still blows the fuse. While the fuse is blown, it still does output sound and works like it should I think? Would like to fix it anyway. Maybe someone has any ideas?
I was not able to attach the schematics pdf (too large file), but added a few screenshots that might help.
