Pioneer SDR-05 CD recorder. Reporting how I make it works, at least for now.
morfeora
Hello friends,
Recently I found this beauty on a local second hand electronics, the state was "not working" and after some talking with the owner, he was sick of trying to make it works, he gave it to me for around 30 USD. I did the research before and knew this was probably a good piece, some places says it is a high-end model, so I accepted the deal.
The unit was not reading any CD (I mainly wanted to play CDs, not so interested on recording, at least not for now). After some research I found here by @dr-tinear that there was a supercapacitor able to cause a lot of trouble. So I proceed to check this and removed as they suggested, but the problem was not solved.
So I went to read the service manual and found under the adjustment session one adjustment that was pointing directly to my difficulties: "Play does not start, track search impossible, track are skipped" It was Playback power adjustment. Being a little anxious i decided to give it a try and move the trimmer for the adjustment a little to see if some change was noticeable and well... immediately the unit started to read and play the CDs!
After that I become more serious about the adjustment, so I take the voltmeter and set the power as manual says it should be 208mv, but this setting returned the unit to its original (not reading cds state). So I turned again the trimmer until the cds play and reproduce without any difficulties which was around 316mv.
On this power the unit is able to read any cd, from very scratched cds to recorded CD-Rs and so far I am very happy with my new CD Player. Still I did not try to record, but so far I guess the record power of the laser should be set a little higher too.
Reading here I learned that this is a usual setting on these units, thanks to the time and the use, led start to lose its power or might be due to dust or dirt inside the lens, something impossible to clean, in this way an increase in the power could make it work again, at the expense of the duration of the led. My assumption here is that to change the laser pickup will be the best practice to follow.
What you think about it guys? Do you think this increase in the power of the led could lead to a damage soon? Or working like this could last another 26 years? (this model was release on 1995). Also any ideas of where to look for the laser pickup unit will be great. The part number PEA1326.
Well guys, thank you for your time and reading, so far I am very happy with this CD player, it sounds a bit better than my other CD player, a Denon DN-650F and that my USB DAC. My impression, but is hard to notice, is that it is more detailed and full in the highs, so I have a better feeling of space and detail. Unfortunately the remote control was missing and now that I am enjoying this CD player this much I started to wish for it.
Finally, but not least, I let you some pics as we all love this nudies :)
Some more pictures...
Cheers!
Rodolfo
Hello friends,
Why is it impossible to clean the lens? Most of them are accessible, I've seen some CD players start to work again after cleaning the lens. Seems like I remember the output of the laser diminished with use on the earlier units, maybe still do but compensated. Cleaning though is something to do.
Thank you @spicer, but yes, It was the first thing I did, to clean the lens. In the article I link to (here is again https://www.repairfaq.org/sam/cdfaq.htm#cdlpwradj ) The author point to a kind of dirt that can be inside the lens, and according to him, impossible to clean. But it is good to know that you also heard that the output of the laser diminished with use, this leads to rise the power as the only solution.
cheers,
Rodolfo
cheers,
Rodolfo
Oh... on the inside... that would be a problem indeed. Read from the link, good information. It's been quite a while since I was inside repairing a CD unit, they used to have good service manuals explaining everything about the format and how the data was handled in the unit as well as servo systems to keep the optical unit tracking and focused... that was back when things were repaired and not automatically replaced. When that unit was new it would almost have to have been considered high end since computers were not yet commonly making audio CDs and a stand alone unit would have quite special. It's a nice piece to have in a system.
Thank you for the piece of history Spice, I didn't realize until you mention the fact this unit came out when no computers were massively include cd-r recorders. This probable give a lot of value to this Recorders. If I remember well, the price was around $2000 USD dollars back then. Quiet expensive for that time.
The manual for this unit is exactly as you mention, a lot of information, and adjustments procedures available. I don't have an ocsiloscope yet but once I have it I will be able to perform al this adjustments. The unit also have a "Test mode" to perform this adjustments. Beautiful!
Cheers,
Rodolfo
