Soup Wins
Hello people of Audio Karma,
I am new here and looking for some help. Hopefully this is the correct place to post this.
I have been trying to teach myself about vintage stereo repair, and have had some good success refurbishing speakers, replacing burnt out lamps in receivers, and other simple tasks. I've had good fun, and made a little money cleaning up and selling systems locally.
I have now run into a technical repair with a Pioneer Spec-1 Preamplifier that is beyond my skills to fix so I was hoping someone on here might be patient enough to walk me through the diagnosis and repair of this old gear.
The problem is that no signal is making if from any of the inputs to the output section. (Yes, I am aware that it is not an amplifier, and have hooked it up correctly). I have downloaded the service manual for this unit, but am not super confident in reading it. Opening up the bottom panel I found fuses numbers 2 and 3 were expended. I replaced them and they burned out again instantly on startup. I was able to deduce that those fuses are connected to the power supply board, AWR-094A.
I would appreciate any help and guidance on what to do next. The power supply board looks fine, no obvious damage, so how do I go about diagnosing the problem? Please bear in mind that I don't know a whole lot about electronics, so please use layman's terms if possible.
Thank you to anyone who reads this.
~Benjamin
Here are some pictures of the unit and power supply board.
~Benjamin
