The diodes are most often used to set up the proper bias current...the diodes get it 'in the ballpark' (on the low side), and you fine-tune with the trimpot to get the proper voltage between the bases of the driver transistors, and thus the proper current through the output transistor. The difference between a STV-3H and an STV-4H is about 1/2 a volt or so, and that ought to be enough (if you swapped a 3H for a 4H) to reduce bias current to zero. The amp will work, but not well. You could use a larger trimpot to increase the voltage drop, but it can end up making the amp thermally unstable.lorne said:QUESTION: have I hamstrung the amp in some way that I am not detecting? Can you explain why our results are so different?
God no...NEXT: do you do a resistance reading for each R when you rebuild,
In every design there are resistors that take a beating. Learning where they are is part of the game. RE: Voltages. I check all regulated and unregulated voltages at the source. As far as the rest of the voltages in the amp, if the semiconductors and caps and resistors are doing their job as they should, then they'll be about where they should. Bench testing with dummy loads and signal sources can ferret out symptoms that can lead to the discovery of components that are 'working', but perhaps not as well as they should.or do you read voltages down the line?
Depends on if there's a problem that you can't find. I got better things to do than pull transistors out of a working amp and test them. The diode test is a crude one, and useful only for finding gross failures.Is there any point in checking every transistor on the board for comparative readings in the instrument’s 'diode mode'?
Depends on the condition of the old ones. If they are cracked or chipped or too thick (many old mica insulators are too damn thick...you want thin) I replace 'em. Sometimes I just don't feel like cleaning them.AND: Should we replace the mica insulators on the output trannies? Recently I just cleaned them up and reused them because I found that the ones I hand on hand were the wrong size (smaller).
Pioneer used a clear thermal compound that set kinda like epoxy for some time back in the 70's. Perhaps you had one. The one with white grease may have been removed by someone at sometime.ALSO: In a Pioneer SA-8500 (Jpn model 8900) I found a 2SC1626 with no thermal grease. The 2SA816 on the same board (switch control) had grease. Is this weird?
Sounds good to me.I'm using the only grease I can get locally in a computer building supply shop. It's from Sunhayato (Tokyo I think) — a silicon grease rated for 200 Centigrade. Sound OK? — LORNE
