Hello and thank you very much for the advices. You were right.
The problem is solved. Some transistors were not properly oriented, diode D1 burnt down several times, 150 ohm R6 suddenly burnt (after getting very hot). In the end all output voltages were OK except for #11. Voltages at Q5 and Q7 werewrong with base volages zero. At this point I checked all the resistors and found that one, 4.7 k R10, which is between both bases of Q5 and S7, had one leg that was simply not soldered to the board !!!
That settled things and all output voltages are ok now - a tad too high (.6 to 1 V) though.
I wonder if this is due to the output voltages from the recrifier bridges are too high. Thus is a 110 volt unit that i am powering with a 220-120 volt transformer - I am in Europe and we run on 220-240 V/60 Hz
If someone knows what are the output volages at the transformer outputs for US units that would be interesting - I plan to fit the receiver with a custom made 220 V transformer.
Morale:
- check very, very carefully transistor orientation. Even though i knew somr xere ECB not BCE i made mistakes.
-if you want to renovate the power board on those receivers I would advise to just change condensers (assuming there is no other problem and it functions). Especially if you are over 70 !
- and if you need a brand new AWR-101 powerboard, write me, because i will make several new ones !
