Hello.
I have been working on repairing vintage gear as a hobby for about 2 years with reasonable success - mostly because of the great information and guidance here on AK.
I have read and re-read the existing threads here on sx-1000 troubleshooting and have made great progress on a unit that came to me DOA (from *bay) - I've been able to bring it mostly back, essentially, left channel now sounds good, right channel has lower level and is badly distorted. Hoping you good folks can help.
I should mention that this unit was clearly worked on by someone else previously - plenty of bad solder joints and lifted solder pads (main amp board and power supply board) that I have re-floated/fixed.
Other work done to date:
Replaced all .7 power resistors with .68
Rebuilt power supply board (all but rectifier diodes) voltages:
1 - 0
2 - 35.4vdc
3 - 35vdc
4 - 0
5 - 76vdc
6 - 37.2vdc
7 - 44.9vdc
8 - 11.4vdc
9 - .2vdc
10 - 0
11 - 20.5vdc
12 - 0
Main amp board: left side has all new transistors (followed advice here - check and rechecked that they are correctly installed) replaced resistors that had fried (R846/R848) or were out of spec. All new lytic caps as well on left side only.
Replaced Q1/Q3 (have also swapped with Q2/Q4 to see if distortion followed - it did not) I have another set of matching Transistors for Q2/Q4 which I will install once I'm certain all is well.
I am seeing drastically different voltages between channels on the main amp board pins- 7,8,9,10 are much lower on right side - I believe this is a clue to what's amiss (?)
Here are the power readings:
Left (good) side:
3- 45vdc
4- 0
5- 0
6- 76vdc
7- 42.3vdc
8- 42.3 vdc
9 - 41.8vdc
10- 41vdc
11- .4vdc
12- 0
Right (Bad) side:
3- 45vdc
4- 0
5- .1vdc
6- 76vdc
7- 10.7vdc
8 - 10.8vdc
9 - 9.8vdc
10 - 8.7vdc
11- .8vdc
12- 0
Note: I have not tested/replaced D1/D2 diodes as I'm not clear on how to proceed.
Look forward to your collective wisdom - Thanks in advance
1 - 0
2 - 35.4vdc
3 - 35vdc
4 - 0
5 - 76vdc
6 - 37.2vdc
7 - 44.9vdc
8 - 11.4vdc
9 - .2vdc
10 - 0
11 - 20.5vdc
12 - 0
Left (good) side:
3- 45vdc
4- 0
5- 0
6- 76vdc
7- 42.3vdc
8- 42.3 vdc
9 - 41.8vdc
10- 41vdc
11- .4vdc
12- 0
Right (Bad) side:
3- 45vdc
4- 0
5- .1vdc
6- 76vdc
7- 10.7vdc
8 - 10.8vdc
9 - 9.8vdc
10 - 8.7vdc
11- .8vdc
12- 0
