Nuel
Good day. I've been working on a Pioneer SX-1010 that has issues with its Phono board. It gives out constant cracking noise, sometimes very loud, getting the amplifier into Protection Mode. This issue is only in the Phono stage. All other inputs work fine.
With some investigation I found the issue was only with the Right channel of the Equalizer Board AWF-013-0 . So I started off with replacing the electrolytic capacitors and transistors on only the Right side. From other posts, I understood the difference in pin configuration with the modern transistors, so I checked multiple times to install them correctly.
The issue persists and I have no idea what's going on.
I took the voltage measurements and parts of the Right channel definitely has incorrect voltages. Haven't been able to get to the bottom of this.
The below image has the voltages at different points, green for correct measurements and red for incorrect ones.
Would appreciate any help.
Thank you.
Thank you.
