rowingcoach
ah man, I am sure MTF or one of the other resident geniuses will chime in.
Keep positive. You're getting closer. :thmbsp:
Thanks. I was very careful and used a desolderinggun on ALL the parts to remove the solder, and put each part in the right way. It 5, 4,3 2, 1 CLICKED on each board I did all the way till the end. I messed something up cleaning the back of that board. I wonder if the crust was crystalized 1970's Pepsi. That is the color it was. brownish rusty clear. and it was not on entire board, just down the sides of it. UHG.
upon reflection..... I did ONE additional thing while I had the boards out to clean them. I replaced two more transistors. Q8? and the other one of same value. I think they were Preamp ones. I had one in wrong! ****. The Base and Common were reversed. DOH! Nothing had blown up at that point, just no 5, 4 3, 2, 1 CLICK. So i fixed it and in doing so I pushed the trace away from the board. I did my best to flatten it out again and solder it in place without touching any other nearby daps of solder. Is the trace separating slightly ok? Wont enough solder around the base of the transistor make enough a circuit to where the trace exposed ring should be to work? Hmm?
In any case, I can see that board being a lost cause with all the crust I scraped off, although careful I just can't be sure it was totally clean and who the hell knows WHAT on earth that junk was and if it was/is conductive and shorting something.
