No signal no load draws about 5 amps. Both amplifier heat sinks get scalding hot. The +56 v power supply regulator transistor gets hot. +56 is .5v lower than -56. Differential amp transistors have been replaced. Worked for a two years since then. Maybe one has failed? both channels get hot along with regulator heat sink.
No dc offset and idle current is normal. Any suggestions are appreciated.
