Pioneer SX-1250 Dial Lamp Issue
xXColdShotXx
I have rebuilt every board in my SX-1250 except the tuner. I have an issue with the 4 main dial lamps going from barely lit dim to kind of bright randomly. Has anyone else had this problem or does anyone know what may be the problem? Thanks.
AWR-107 FU5 1.5 amps blue transformer wires. pins 12 (out) & 11 (in) - one blue wire transformer winding wires is grounded.
AWX-096 grounded. IF not the fuse, check the wires and connections.
I've tested the wires going to the 4 bulb rail before and it showed 6 volts or so. Since that purple wire from pin 12 goes to AWM-091 protection circuit board pin 2, would it have anything to do with the popping through the speakers when power is turned on and off?
6VAC seems low for the lamp V.
The wire marked as "A"on the big schematic (~7.5VAC) is used for the AC presence detection on AWM-091.
do you have a bad contact at the fuse holder on AWR-107? or the 1.5 A fuse has issues?, measure the VAC on both sides of the fuse holder, with respect to chassis ground. could try measuring with the fuse (FU5) in & out too.
bad or poor ground connection for the blue transformer secondary wire.
rotate the fuse in the holder, sometimes they oxidize and make bad connections
Good Luck Rick
I finally figured out the dial lamps issue. The purple wire peg on AWR-107 board was loose.
