Michael Bishop
My Pioneer SX-1250 has developed a problem where the FM muting between stations no longer works. With my volt/ohm meter, I have verified that the issue is not the muting switch, nor the wiring from the switch board to the FM tuner board. Looking at the FM tuner board, I see no obvious visual signs of bad capacitors, or bad solder joints. There is the Reed relay (part: ASR-005) which supports the FM muting function, and I'm wondering if the trouble lies in there? I'm told the Reed relay is not serviceable, and must be replaced, if that is the source of the issue. One thought is to re-solder around the existing Reed relay - but have not yet attempted any re-soldering. I only have a volt/ohm meter (no other test equipment) and would appreciate any advise on troubleshooting this further.
Many thanks to AK members!
