bernie Stag
I have a Pioneer SX-1250, great classic item. I am not good at the ohm language and classifications for speaker impedance. I have to pairs of 4 ohm speakers, one pair is the Paradigm model 9se the other pair is a set of DCM Time Windows. I want to understand/know if it is ok to run both pairs together with the A+B switch selected.
I know that I can run either pair on any of the single channels @4 ohms, but not sure if I can run them both together on A+B, A+C, B+C, with the impedance showing that "8ohms" or more is recommended when doing this, but it is not listed as a minimum, so I don't get it. I don't want to burn anything up as it is quite an expensive equipment replacement at todays prices.
Is it safe to do this, as I do not understand the difference between Parallel and Series wiring either, or whether the receiver is wired in series or parallel either.
Thanks for your time and understanding.
B
B
