After replacing all the capacitors, resistors and transistors on the Left and Right Power Amp boards, I finally got the zero volts needed on the bias and finally got the 2nd relay to kick in - releasing the speakers.
However, the Left channel is very weak coming out of the speaker. Using all the sources - FM, AUX, etc. produce the same weak output to the speakers.
1. The speaker is good - when I switch leads, the other speaker becomes weak.
2. It's not the pre-amp or flat amp (volume, balance, loudness, etc.). I connected the pre-out to another amplifier and the output is equal strength out the speakers, the volume and balance control is perfect too.
3. I connected a DAC into the inputs of the "Power In" (amplifier section) - the same weakness to the Left channel is present.
4. The 4 big filter capacitors (20,000 uF) are new.
5. Full re-cap was done on the following boards:
a) Left Power Amp (new resistors too)
b) Right Power Amp
c) Power Stabilizer (new resistors too)
d) Protection Circuit (new resistors too)
e) Flat Amp
f) Tone Control
g) Power Supply
6. The Speaker Protection Relay is new (on the Protection Ckt board)
Some of the diodes on the Left Power Amp board are the only ones I have not replaced. Maybe this is the cause.
Will other boards (other the Power Amp board) make this effect?
Any suggestions would be helpful.
Thanks.
b) Right Power Amp
e) Flat Amp
f) Tone Control
g) Power Supply
Thanks.
