JB8
Well-Known Member
Hey Pioneer experts and enthusiasts!
I have a beautiful SX-2500 that I've grown quite fond of (damnit) shouldn't have let myself get attached but here we are...
Overview:
Ultimately at this point my two most pressing issues are the FM stereo distortion and fixing the filter switches, so if anyone wants to chime in on any of what I'm listed please pile on. OK, I'll shut up now.
Overview:
- Autotune seems to work but I'm not worried about that for now
- Has moderate ground hum, not a crazy-loud one, but annoying none the less, not a major concern, yet
- I've recapped and replaced the 458's on the Head Amp - will replace the remaining 458's on-sight across the Control and Main Amp boards eventually
- Replaced main filter cap (HUGE cap!) it was testing at 5400 uF so it felt like a good call to replace it
- Will be replacing the axial 100v 100uF caps tonight, they were testing at ~230uF
- Unit sounds fantastic when listening to source via AUX inputs - very clear, very strong, amazing sound in my opinion
- FM has distortion when tuning in stereo stations. If you roll off the stereo signal and the dial needle goes dark the signal is clearer, but if I roll back and the light comes on, I get some increased separation, but it's distorted out there, hard left/hard right (Stereo Station and Local Station buttons have no impact on the sound)
- I replaced the two 47uF caps on the FM IF board having read a different thread on this that they can be problematic, no change. Assuming it's one of the chips on this board? Anything else I should be checking?
- The High/Low Filter switch must have been bumped at some point so it has a fracture across both switch housings, the result is the low filter switch engages fine but the high switch will not engage and click in
- Do we think this switch can be repaired or will it require replacement?
- All switches have been thoroughly cleaned - I know cleaning is the #1 coaching given for Pioneers with some of the issues I've noted, so rest assured, I've cleaned the crap out of them
- All but the "AM" function lights are out but all other lights are working
- Does having burnt out function lights have an impact on the performance of the unit?
- The signal meter is working, tuning needle is stuck and not working - it's frozen left of center
