There are NO Screws on any of the Knobs on the 424. Flip the Unit on it's back. Take some old washcloths and put on either side of the offending knob. Then take TWO spoons, and slip them under the knob on opposite sides. Push DOWN on the handles evenly. The knob will pop off eventually. The problem is galvanic corrosion of the brass pot shaft and the aluminum knobs.
Once the knobs are off, undo the 2 or 3 nuts on the front (1/2" or 12mm box wrench), then 2 screws on the top of the face, and IIRC 2 on the bottom.
There is a plate that secures the dial glass to the frame. remove that (2-3 screws), then remove the dial glass.
There are 5 Fuse type bulbs. 8V .3a rating. also the meter takes 1. Either replace the bad ones or all of them and keep the good ones for spares.
Reassemble and enjoy. I've got the 424 and 434 and like the 24 a little better for it's sound, but like the 34 better for it's speaker connectors. Granted i've got all the connectors for the 24, but they are a PITA, excpet when I change to the QX747A or QX-9900, then it's plug and play!
Larry
