Walterramjet
Yesterday, I received my new-to-me Pioneer SX-434.
The ad on ebay said it was recently serviced and in good working order. The trouble is, I discover after plugging in that the only thing working are the dashboard lights. That makes sense because the transformer secondary that feeds the lamp circuit goes to the power board, then through a mini-fuse and leaves the board and onward to the lamps.
What I dont know for sure; What are the engineered voltages of the power transformer secondary taps supposed to be? None of this info appears in the service manual or on the drawing. I do see what the DC volts should be around each transistor and power board output (B+ etc...). It would be nice to know what the power transformer's secondary AC volts should be for terminals 9,7, and 8 on board AWR-062. The scratch-pad has the measured values with 120vac supplied to the primary. Thanks
